Swamp,
just a word of caution on this (and any chemical/s) that we all use:
Every manufacture must make available to the end user/general public a current copy of each products MSDS (Material Safety Data Sheet) and this one's here:
http://www.acf-50.co.uk/acrobat/ACF-50A ... 11MSDS.pdf
click on the link and thoroughly acquaint yourself with all of the advice and in particular any PPE (Personal Protective Equipment) recommendations, after all, a bloke of your age needs to look after himself.....
If anyone has a pre-disposition to Asthma or any other upper respiratory tract sensitivity, they should either wear an appropriate respirator at best, ...or worst.... wheel your beloved (not the misses, the other one
) outside and go for your life.
Also note its an oxidiser, (might make oxygen when mixed with other stuff during a fire)....(not good)...
Looks like a couple of long eared fluffy bunnies also contributed (sorry committed
) to the test results...
Are you planning to use this product carrying out your new income building scheme? ................................................or keeping for your shiney, shiney GS (Generally Shiney), very shiney ??
How much is this gear anyway ??
