Hi,
I've somehow manages to sheer off the lower screen fixings on my GSA, they look like a shoddy design in the first place, anyone had any prior experience in replacing these bit of plastic??
GSA screen lower fixing
Re: GSA screen lower fixing
they all come in a kit now, called the windscreen mounting kit, comes with the top adjusters as well. There is an aftermarket kit available which makes the screen on a GS more adjustable.
If buying the OEM kit from Autoclassic lube yourself up before going down there, it'll hurt.
- KoosWA
.bully1 wrote: If buying the OEM kit from Autoclassic lube yourself up before going down there, it'll hurt.
Sorted, not as bad as I thought, I'll save the lube for the HID lamps I want!!!
