Rubber mounts for 1200GS bash plate - two out of four are broken, Had a quick look and the broken rubber appears to be flush with the sump how do I remove these remains ?
Must've perished it wouldn't be from too much rough riding!
Cheers Rob
Bash Plate
- thumper
Re: Bash Plate
The rubber protectors on all the GS's suffer the same fate. Oil/heat is not great for rubber and they eventually go soft and break apart. Once or twice
I had the same problem so far I have been able to grab the edge with a pair of grips and get them started - they have not been wound in that tight and once started was able to just unwind them.
R1150RT
R1100GS
R100GSPD
Bikes don't leak oil, they mark their territory!
R1100GS
R100GSPD
Re: Bash Plate
Thanks for that - I'll crawl around underneath and have go at grabbing them - although one has sheared off pretty much flush. Hmm never thought I'd have issues with broken rubbers at my age.
