Mobile sparky
Mobile sparky
Does anyone have any recommendation's of a mobile motorcycle electrician?
gsrider
Re: Mobile sparky
Guy
What are you having an issue with?
Ross
Ross
Re: Mobile sparky
Hiya Ross...indicators on my Triumph, gone as far as I can there, & an R100 not starting.
Re: Mobile sparky
Hey Guy, the R100 not starting will be the $7 silver relay under the tank on the LHS, you can buy them at any Bosch outlet. Try removing it and cleaning all seven spade terminals with electrical cleaner then try again......If not get a new one and try that before lashing out mega$$$$$$s
Re: Mobile sparky
Hiya John..I swapped that with two others that I have, same result, Ross Ashton mentioned the same, so I will give the terminals a really good scrape. I have put my Triumph into Motorcycle Doctors in Nth Pth , indicator probs. If they seem ok will put the R100 to them.
Re: Mobile sparky
Motorcycle Electrics & Auto Rewinds
Unit 13, 66 Roberts Street
6017 Osborne Park
Western Australia
Contact details
(08) 9242 2388
I used this company to change the XR blinkers to LED units as the conversion needed LED flasher unit as well.
The XR runs AC and DC circuits so need to make sure you get the right components
He was good to deal with and no issues with conversion.
Not sure if he has a mobile service
6017 Osborne Park
Western Australia
Contact details
(08) 9242 2388
