Guys,
The BMW's got a fault.... due to the upcoming reno's on the house the normal method of repair, ie buy another one, isn't going to work, so...
I found the ball joint cover on the telelevers' split open, research seems to say you can't replace the boot alone and must replace the entire ball joint assy as it comes preassembled, so whilst I'm relatively comfortable wrenching, is this a job recommended for the shop or doable at home?
