If you are looking for oil filters maybe this can help
BMW
R45, R560 1969-1972 CH6061 R60 1969-1984 CH6061
R65 1978-1984 CH6061 R65 1985-1988 CH6060
R65 LS 1978-1985 CH6061 K75 1985-1992 [7]
R75 1969-1984 CH6061 F800 S, ST, GS 2006+ [7]
R80G, S, ST 1981-1984 CH6060 R80 1976-1984 CH6061
R80 G/S Paris-Dakar 1987-1990 CH6061 R80 G/S Paris-Dakar 1991 CH6062
R80 ST 1983 CH6060 R80 S 1981 CH6060
R80G 1981 CH6060 R100 RT 1976-1984 w/oil cooler CH6062
R100 R, RS, RT, PD 1986-1991 CH6062 R100 RT 1976-1984 w/o oil cooler CH6060
K1 1989-1993 [7] R100 S, T 1976-1984 CH6061
K100, LS, LT, RT 1983-1993 [7] K1100, LT, RS 1990-1993 [7]
R1100 R, RS, RT, S, GS 1993-2007 [7] R1150 R, RS, RT, GS 2000-2007 [7]
K1200 GT, LT, RS 1999-2007 [7] R1200 C, RT, GS, HP2 1999-2007 [7]
If your bike does not use a spin-on oil filter, the given number is a Fram part number. The filter media from Fram will be of normal quality, and pretty much as good as you can get anywhere else. At the very bottom of this page there's a small cross- reference table relating a few Fram / WIX / Purolator import filters. This will give you a few more choices if your bike uses one of the CH6xxx numbers.
[7]
These Oil Filters have 3/4" x 16tpi threads, ?? psi by-pass valve, anti-drain back valve. Recommended filters in blue. Available filters include: · Purolator PL10241 / PL25230 · Mobil1 M1-102 · Bosch 3330 · Supertech ST3614 · AMSOil SMF 122 · EMGO 10-26740 · Fram PH6063 · Purolator ML16825
Oil Filters
Oil Filters
