Replacement indicator relays for /6's.....anyone tried and tested and recommend a non-std indicator relay available locally ?
Quite a bit on Google and all located in US.
Cheers, Ross C.
Indicator Relay for R75/6 1975
Re: Indicator Relay for R75/6 1975
Ross, I believe its probably better to use the correct BMW part, because it's an exact fit inside the cramped confines of the headlight. You could probably get away with a cheap alternative, but you may have to wire it up outside of the headlight. Vince might have a second hand one for you.
