Thursday Ride December 3 KELMSCOTT DOME
Post by pspencer »
Usual 8:00 departure from Shell Ascot to travel to KELMSCOTT DOME for a 9 ish departure.
Re: Thursday Ride December 3 KELMSCOTT DOME
Post by brian/5 »
A reasonable tridecimal sized group for the morning coffee.
One of the subjects of discussion as to what to call the departing group. Initial suggest wording was to be metric or imperial. At the actual departure time turned out to be between the two so it turned out to be an Undecimal group departure. Leaving behind a non-ride binary group. After Mundijong with one turning back to head for home the group size then turned decimal. With little traffic and group size only several corners need someone to pause to mark the turn point.
A pleasantly quite ride down through the back blocks ending up at the Waroona Bakery. The trip home was up to Dwellingup then back to the highway via Del Park. Good byes were said at North Dandalup with the group splitting to find their own way home.
Post by pspencer »
Thanks B5 for the Ride Report and excellent TEC work. Thanks to all for a great day.
