I have recently added changed the front wheel on my 2010 F650 (800 twin) to a twin braked wheel from an ST800. New SS brake lines are fitted and bled in the conventional manner, clean fluid in the lines and no air.
There is little or no pressure at the lever leading me to the conclusion that there is air in the ABS modulator. Do I need to bleed the modulator as well or hook up the diagnostic to clear any faults in the modulator.
Bleeding brakes with ABS Moduator - problemo.
Re: Bleeding brakes with ABS Moduator - problemo.
OK, just You Tubed it. I need to plug the GS911 in, there is a function that addresses this problem.
