Fuel Consumption
Fuel Consumption
Post by brian/5 »
Fuel Consumption
One hears a lot of comment about fuel consumption and the difference on the grades of petrol.
As I have been recording my refills I realized that the actual RON value in the tank could be calculated.
From what I read it’s a simple ratio so half a tank of 91, filled with 95 then effectively you are running on 93.
Also I have recorded when it was not a full tank refill so consumptions that are not valid has been omitted
2010 R1200GS K25
_____RON_____Litres_____Kms___L/100Km___MPG___Km/Litre___CPL___cents/km
___>90 - 92____687.7____13261____5.2_____54.4_____19.3____157.8_____8.2
___>92 - 93____721.9____13862____5.2_____54.1_____19.2____152.6_____7.9
___>93 - 94____624.6____11677____5.3_____52.7_____18.7____156.8_____8.4
___>94 - 95___1837.6____36266____5.1_____55.7_____19.7____149.2_____7.6
___>95 - 97___2008.0____38717____5.2_____54.4_____19.3____147.6_____7.7
___>97 - 98____804.7____14935____5.4_____52.3_____18.6____150.0_____8.1
___Total/AVG__6684.5___128718___5.2_____54.3______19.3____150.8____7.8
Records from 28/10/10 to 11/07/24
One observation is that the indicated consumption is usually lower by 6 – 10 %
as the actual full tank consumption as its averaging time is shorter.
2006 F650GS R13 ( single )
___>90 - 92___1522.9____38394____4.0_____71.1_____25.2____158.4_____6.3
___>92 - 93____105.0_____2740____3.8_____73.6_____26.1____134.7_____5.2
___>93 - 94_____90.6_____2283____4.0_____71.1_____25.2____143.4_____5.7
___>94 - 95____112.8_____2872____3.9_____71.8_____25.5____136.5_____5.4
___>95 - 97_____34.4______925____3.7_____75.8_____26.9____124.9_____4.6
___>97 - 9 8_____15.1______416____3.6_____77.8_____27.6____143.9_____5.2
__
__Total/AVG__1880.8____47631____3.9___71.4_______25.3____154.3_____6.1
Records from 25/08/12 to 18/07/24
