Tech Talk: BMW R 1200/1250 Series
A list of technical articles that I've put together over the 210,000 kms (and counting) of owning an awesome 2008 R1200 GSA.
ELECTRICs
RDC/TPM battery replacement (Thanks Nurzo for this great article) BMW R 1200 series: TPMS/RDC Refurb BMW R 1200 series: Can you change TPM read out from BAR to PSI? R 1200 Oil Head: Replacing Headlight globes BMW R 1200 series: CanBus and GSA fog lights
ENGINE
BMW Boxer R1200 GSA service and inspection BMW R 1250 / 1200 Variable Valve Timing systems R 1200 Throttle body problems - broken cable pulleys Throttle body balance BMW R 1200 GS BMW Boxer Harmonizer: Syncing throttle bodies BMW R 1200 series: ECU Map modification + StainTune Exhaust Engine Mods: ECU, A/F ratio, Power controller, drive-ability
FUEL SYSTEM
Throttle Body Shaft Replacement due to broken sector plates Fuel Pump Replacement Fuel system cleaner / injectors / fuel gauge strip BmW R 1200 GSA Fuel Tank Flange Crack (RHS)
DRIVELINE
BMW R 1200 22 spline drive shaft failure and replacement R 1200 RT drive shaft failure BMW R 1200 series / K1200 series: final drive repairs
SUSPENSION
BMW R Nine T Scrambler / UGS + Wilbers long travel suspension BMW R 1 200 GSA (2008) ESA Shock Absorber Removal
BRAKES
Working on Brakes: Rule Number 1 BMW R 1200 series: ABS Unit repairs
WHEELS AND TYRES
Motorbike Tyres - Talk about tyres you've owned
SPECIFICATIONS
BMW R 1200 GS series Specifications by Year BMW R 1200 / 1200 GS Adventure gear ratios
Raider
Re: Tech Talk: BMW R1200 Series
Post by Raider »
Spacey1,
An excellent list. However, after scanning it seems to be missing the most important item. The one about what to do when the service interval is up or there is a problem or other, including those listed…
Add this to your list: Call Auto Classic or Thorsten etc and make a service/repair booking. Just need to add a phone number or two. Then there is, of course, a requirement to find a way to get home and a way to get back when the bike is ready.
Cheers,
Raider
So you'd be referring to:
Service / Parts / Repairs in Perth
http://forum.bmwmccwa.asn.au/viewtopic.php?f=4&t=78
:P
jls
Post by jls »
hey spacey
toying with the new to me 2005 1200 is the gs 911 worth it
A very informative article from Nurzo: RDC/TPM battery replacement
jls wrote:hey spacey
At the very least, a GS 911 can record all relevant data from your BMW's ECU (computer), save that information to a text file which you can then save to your mobile phone.
Then you will have an accurate record of your BMW motorcycle on your phone in the case of a breakdown occurring.
The BMW spare parts people will be able to more accurately assist identifying parts for your BMW motorcycle.
Added:
R1200 Oil Head: Replacing Headlight globes
Re: Tech Talk: BMW R 1200 Series
Added:
Added: Fuel Pump Replacement
Added: Throttle Body Shaft Replacement due to broken sector plates
