All Balls
- profoundly_disturbed
All Balls
As the boredom sets in, here's a little light entertainment that demonstrates the manufacturing process of a product that everyone of us uses every day. Simple, but the engineering is superb, although the subtitle translation is sometimes odd!
https://youtu.be/19duYMdiXi0
Fourteen minutes of your life you won't get back!
Re: All Balls
Prof Disturbed I was not sure how the burs and flashing machines took away burs and polished the balls.Something about a fixed plate against a rotating plate with spiral grooves on it. Can you explain the physics of what’s going on here. As at this stage the balls have been heat treated to increase their hardness and to get them exactly spherical and polished there most be a form of grinding involved. I fail to understand how the rotating plate with the spirals manages to trim the balls up. Maybe with your vast knowledge would you be as so kind to enlighten one as to “ how is it done” as the eminent Prof Julius Sumner Miller used to say as he went on to explain .
Re: All Balls
Have seen it before it is actually interesting. I think they put raw balls in /6 gearbox’s they did seem to fail a lot also costed me a lot of money replacing them
Re: All Balls
Fantastic video, I feel sorry for the person doing the visual inspections.
I made a part for my bicycle on the lathe yesterday, I'm capable of turning perfectly good material into Scwarf ... sometimes the item actually works.
Re: All Balls
So Mr Profoundly Disturbed, does the next episode explain how they get the balls into a ball bearing,...always wondered about that!
Re: All Balls
Bowe
There will be a race to let you know how it is done.
Re: All Balls
You may well be right, but I'm going to be a little cagey.Bozo wrote:Bowe
Re: All Balls
Due to public demand, for those of you that asked (BillB and Bowe), and those who didn't (everyone else), a video to show how it's done!profoundly_disturbed wrote:You may well be right, but I'm going to be a little cagey.Bozo wrote:Bowe
https://youtu.be/b6svVy1lYOA
Re: All Balls
Prof Dist
It seems the thrust in interest has transitioned to a taper which has a bearing on the cessation of posts.
Re: All Balls
It sounds like you're bushed. I've got the needle so let that be an end to the journal.Bozo wrote:Prof Dist
