Pipe clean
cutting it
Pipe clean
Want t clean my exhaust pipes up... mainly it's the headers.. what / who do peope recommend.. thinking it would be easier with an acid bath etc
Re: Pipe clean
I used Autosol, but it took a lot of elbow grease. result wasn't too bad though.
kev
Re: Pipe clean
Probably worth giving Dave Munro at Beter Motorcycles a call. I think it was he who gave me the name of a business in ? Myaree/Melville who does that sort of thing. He also could advise on products.
- thumper
Re: Pipe clean
It depends on how good a job you want done - you can have it professionally done and because it is very labour intensive can be expensive - but it does give you an almost or good as new look. For the headers another option is to use 600 wet and dry (wet) and gently rub it down - dont use a lot of pressure just keep it wet and it will get all the brown off and return it to a polished stainless steel look - but still with the 'blued' look. If you a stronger grit or too much pressure you run the risk of leaving little swirl patterns in the steel. If you want it better than that then you can use metal polish and a lot of rubbing. The professionals use a polishing wheel and a lot of patience.
R1150RT
R1100GS
R100GSPD
Bikes don't leak oil, they mark their territory!
R1100GS
R100GSPD
bmwlefty
Re: Pipe clean
I got a bench grinder with polishing wheels and polish, if you want, I can give it a go.
cutting it
Re: Pipe clean
Thanks lefty.. i'll make some time and tee it up with you... i'll grap some wet/dry papper as well.. fly out for work today.. make a time when i get back
nickbrett
Re: Pipe clean
Regarding pipe cleaning,
I used a business in Myaree called Metaglo to polish the full system on my '82 R100 and they did an immaculate job, at what I considered a most reasonable price. Additionally, they sold me a polishing product 'Lightning Shine Metal Polish' by Wicked Products which I have used since (probably not as often as I should!) and even with sparing use returns the pipes to a high level of shine. Without reservation (and with no alternative agenda) I'd recommend both service and product. Cheerskev wrote:Probably worth giving Dave Munro at Beter Motorcycles a call. I think it was he who gave me the name of a business in ? Myaree/Melville who does that sort of thing. He also could advise on products.
