Thursday December 12, MOJOS MUNDARING
Could be a bit warm but like a shark we’ll just keep moving.
Leaving Gloria Jeans Ascot at 7:30am to glide up to Mojos Mundaring for a 9:00ish departure. DDD
bmwlefty
Re: Thursday December 12, MOJOS MUNDARING
If I miss you at Ascot, see you at Mojos
11 at Gloria Jeans for an easy run up to Mojos with another 2 there to be joined later by 3 Dominicans. So considering the heat an excellent turnout. I had decided a run on the Talbots with lunch in Beverley would be OK. But only had four others for part of the way, turning off to York while I did a solo to Beverley.
Decided I felt like Sushi so I enjoyed that with a Ginger Beer sitting outside the Bakery in 36 degrees with a light cooling breeze. Very nice as I watched the Beverleyites do their thing.
The Talbots are blissful riding so back the same way too easy with temperature rising to 41 degrees as I descended onto the Sandplain.
Thanks to all that turned up GJ’s and Mojos and my excellent RT mirrors to check the TEC didn’t get lost
. 260klms back home by 1:30pm and not as hot as expected. Worth the effort.
