R1200 can you change TPM read out from BAR to PSI?
Yes you can..
I have wanted to change the Tyre Pressure Monitor read out on my R1200GSA from BAR to PSI for some time. Now there is an easy way.
Using the clubs GS-911 Diagnostic tool you can change the display settings for a number of the on-board monitoring functions
It's simple and quick. Not only does the GS-911 allow you to change these configurations it will also list any fault codes that may be associated with the Engine, ABS, Alarm, CanBus etc and allow you to see what the error is from before allowing you to clear it. You can update the service details and next service due indicators.
Just another handy benefit for club members
Re: R1200 can you change TPM read out from BAR to PSI?
:?: Hi Hermann. We had one early December, so hopefully around February or so.........
Now can one have the readout in kPa?? John
